Hi all,
Not really done much oc'ing, certainly not on more recent CPU's anyway.
I've just got a 8700k, ASRock z370 extreme4, 16gb 3200 8 pack ram, d15 cooler (only using the middle fan currently) and no gpu as my 1060 gpu is still on my old pc.
After some playing with the settings I am at 4.8 (target speed) with the following changes:
v-core: 1.29
llc: level 2
Short and Long load set at 170w max
AVX negative offset: 3
Tested using some benchmarks, but mainly from running Prime95 (version 26.6 as the more recent versions seem to get crazy hot due to the AVX I believe?) blend for 2h.
Here is a screenshot during the Prime95 after 2 hours:
Anything I have missed or should change please?
Many thanks.
v-core: 1.29
llc: level 2
Many thanks.
 Let me know how you get on with the delid
