- 2 Feb 2009
- London
Hi folks,
I'm looking for a general purpose PC for home office use. Tons of web browsing with loads of tabs open, multiple spreadsheets, some picture editing with Lightroom and general media use. No gaming expected. The main point is that I want to run a minimum of 2 screens at a minimum of 2560. I plan on upgrading the monitors to a pair of Dell U2715H (although I could be talked into having one monitor to a higher spec).
My old PC was an Acer Revo i3 with 4GB of RAM hooked up to a pair of 24inch monitors. I'm really fed up with the machine slowing down and generally taking forever to do stuff so I'm planning on whatever I build having tons of RAM, at least 16GB. I guess the key point for me is that I want to set the thing up and then forget about it for a few years...
Must be quick to boot, relatively quiet, be capable of running at least 2 screens & have wifi onboard.
I started looking at builds on mid-size cases but was distracted by the Intel NUC. I spec'd out:
Tall Baby Canyon NUC7I5BNH Core I5-7260U
250GB Samsung 970 EVO
500GB (maybe 1TB) Samsung 860 2.5 for data
Corsair Valueselect 16GB SODIMM DDR4 2133MHz
Then I found out about the soon to arrive Hades Canyon.... Do I need it? No. Does it address all the things that niggle me about the Baby Canyon? Yes! Especially moving that damned audio connection to the back.... It's also totally up to date in connectivity terms which is a big plus for me.
So why am I here? I'm keen to go back and take a look at a build on a mid sized ATX tower (or even a micro ATX box) that ticks the quiet and future proof boxes.
I like the Fractal Design cases and wouldn't necessarily go water cooled straight away, rather see how quiet they are with standard fans and go from there.
In terms of chip I'd like to stay in the middle ground of i5 or Ryzen 2600 (heard good things about STOREMI in particular, would enable me to add huge storage for similar/less money compared to a data SSD).
For the Mobo I'd want NVME, WiFi and USB C/3.1 Gen 2
A quiet video card with Displayport and the ability to run 3 monitors would be nice.
Would want to mount a 970 EVO 250GB for the OS and another SSD for primary data drive. Space permitting, I'd add a third drive for scheduled backups (but that's optional).
Budget isnt really a big issue as it will be a company PC, but 1200 for the PC itself absolute max (keen to see what could be done for less)
Loose criteria I know but keen to see what people would suggest.
Cheers
Dave
Cheers
Dave
alit GeForce GTX 1050 StormX 2048MB PCI-Express GDDR5 Graphics Card
