Its just the AE-5 with additional RGB stuff isn't it?
I don't see any specification changes. If they've updated this for a white cover and new RGB stuff, what a joke...
New Pure Edition out now - https://uk.creative.com/p/sound-cards/sound-blasterx-ae-5-pure-edition
It's been out a while. Just a white cover afaik, RGB is still the same. No other changes.
It comes with extra RGB accessories - as far as I can tell that and the fact its white are the only differences.
Would this be good to use with a sound bar? I’m going to be using my pc with a Samsung 49mu6400 4K tv with the Samsung hw-ms650 sound bar with the optional wireless rear speakers(swa9000s).
Its a pretty decent offering for gaming - the way they've engineered the output from the DAC with the LM4562 opamps and the rest of the headphone amplifier means that you get very clear sound with good separation of elements in the sound which makes it easier to pick out the position of sounds. If you use the Acoustic Engine its possible to get decently immersive surround sound in headphones with a much better distinction of whether a sound is coming from infront or behind you than some other systems though there is a little bit of echo to the surround encoding - doesn't quite manage as well as the Sennheiser GSX which manages to keep the sound a bit more natural when encoding surround cues but it is one of the better options in that respect.
EDIT: One thing in relation to gaming - some of the Direct modes like Direct HP seem to act like exclusive mode even with that disabled - some fullscreen games will knock out sound to all other applications - they'll still act like they are playing audio but nothing happens - if you play games with voice comms, etc. you may need to configure one of the non-Direct modes in the Sound Blaster Connect software.
Is the acoustic engine on and surround set to around 60-100%? I don't find the test in the connect software very good - the rear speakers sound the same position as the side ones to me and the fronts only slightly removed from the side ones - but in actual gaming I get a much better representation of front and back.
Game should be setup for 5.1/Cinema sound for best effect - the OS should switch to 5.1 output when you select 7.1 HP mode in the Connect software but you might want to double check that and also maybe fiddle in the Windows speaker settings with the speaker size (range) setting. The surround system used by the AE-5 is different to CMSS-3D with some pros and some cons - I can't quite pick out the distance to a sound source with the AE-5 as well as with my old XtremeMusic but I find the sounds movement more seamless and front/back representation better.
If you are using Windows 10 make sure the new Sonic Surround stuff is disabled as that will conflict with the surround setup the AE-5 uses.
