- 25 Nov 2005
I find it stupid that one needs to get permission to build things on land they supposedly own, it's not like the house is an eye sore
Because it affects other properties, it needs basic checks to make sure it's safe (none of the Spanish loophole*), fits the local area (I'm sure you wouldn't be happy with a neighbour building a small block of flats next door), and because basically if you don't set out rules you will have people being utterly stupid about what they build.I find it stupid that one needs to get permission to build things on land they supposedly own, it's not like the house is an eye sore
IIRC all applications have to be (at the minimum)Yeah i know how planning permission works.
But these plans aren't canvased to neighbours, they are supposed to be "notified" but in the same sense i don't specifically know the guides regarding notification.. as far as i know it could follow a Douglas Adam's HHGTTG style..
The article made it seem like they had built the house without permission then tried to seek retrospective for the whole thing, which would quite obviously raise objections..So I went to view the publicly accessible planning applications and it seems to boil down to this:
The 2013 drawing actually has a note on it to specify that the house would be constructed at a ground level half a metre lower than the neighbouring house. The 2016 version of the application which was the last one before construction revises the windows and draws the house even lower than in 2013.
Then the retrospective application in 2018 shows that they didn't dig it down at all. There is an attempt to suggest it is lower but it's not very convincing.
Complaints about the windows are wishy washy since the redesign of those was present in the 2016 application.
you don't "accidentally" build it 30 inches too high
I imagine the builders built what they were told to build.
My experience of builders is that they won't deviate from the architect plans without jumping through hoops and getting sign off.
Unless they well and truly cocked it up however.
No sympathy from me. Looks quite garish anyway, down with this sort of thing![]()
200k sounds steep to me but I suppose you need to factor in that it's complete and decorated and they are living in it. You can't simply lower a roof either, it needs fully scaffolding and taking down and the timbers (if not trusses) cutting. If they are trusses they need replacing, either way v.expensive.
At a guess 200K is gonna be conservative on that design if they need to actually take out trusses, etc. lowering or reworking the roof in any fundamental way. I am kind of hoping the builders were lazy and decided to cut corners not lowering the ground properly, etc. in the first place and get slapped for it. I'm kind of tired of the half-arsed approach so many companies like that seem to have these days - it almost looks like they've decided to shift some of the drainage problems onto the neighbours rather than properly implement it on their side as well.
