Hi Chaps,
In light of the GPU price madness at the moment, I'd like some help in diagnosing an issue with my IceQ HD 7950 as it's still a really decent card (or should be).
The problem I'm having is that it refuses to operate at anything more than PCI-E 2.0 x2.
The card was originally my brothers and he had a similar issue with it.
It will play a lot of A - rated games and slightly older A-rated games, perfectly fine at 2560x1080 resolution - I have an ultrawide monitor (at the aforementioned speeds) for example, GTAV runs perfectly well, as does Dota2, Civilization 6 on full graphics - but it's starting to come unstuck on bigger games, in particular, I just installed Battlefield 1 and on the small maps it is fine on medium graphics, but the larger maps are almost unplayable.
As I understand it, from various internet research, the 7950 is still a decent card and should handle BF1 on high settings perfectly fine @1080p, without lag or huge fps drops. So I think it is getting massively bottlenecked by the x2 bandwidth.
Any ideas? My old HD6870 runs as it should still, and the 7950 did the same thing in my brothers PC, so I know it's not a motherboard issue..
Just in case you need my spec:
AMD Phenom II 1100T X6 Black edition
16gb Ram
840pro SSD
16gb Ram
840pro SSD
