- 10 May 2004
- Sunny Stafford
I use a Pi-Hole at home which blocks ads on all of my devices at the router level. (for more info about Pi-Hole, check the Linux forum on Overclockers).
When I'm out though, the ads re-appear and they are a drain on the battery. It's unnecessary. I'm talking mainly inside of games as opposed to web browsers. Just killing 20 minutes on my commutes etc.
Does anyone here use an adblocker that doesn't require root? A friend of mine has 1Block which looks ideal but it's iOS only.
I'll give that a try. Especially interesting that you can also use a HOSTs file.
I have white-listed apps that use lighter ads e.g. AccWeather. Lots of apps I pay for anyway. However, for resource hogs, it's curtains I'm afraid. After all, I am the customer and have capacity, and I can make my own choices. If the devs want their ads showing, then use better choice of ads in your apps, m'kay.
