How is running with these in? Any chance of them falling out while I'm on a run?
I always thought these looked ridiculous... but after my Sennheister Wireless earphones died I picked up a set after getting an iPhone 8, these things are brilliant, sound good, work great with my iDevices and it’s handy having the touch controls.
Which Sennheiser earphones did you have?
Thanks. Fairly decent earphones then. Can you compare the sound for me please? I use some momentum 2 on ears with a dragonfly dac on an iPhone 7+ and the sound is pleasing to me. Obviously it’s a ball ache carrying it all about and I have been contemplating some of these for when I want to be a bit more portable. I have been using the lightning to 3.5 converter with the same headphones and they are ok. However, it’s not the best solution in the world. Aside from the fact these AirPods look completely ridiculous, how good are they? I mainly listen to FLAC files and occasionally Apple Music.I had a set of Sennheiser Momentum Free wireless earphones before
Thanks. Fairly decent earphones then. Can you compare the sound for me please? I use some momentum 2 on ears with a dragonfly dac on an iPhone 7+ and the sound is pleasing to me. Obviously it’s a ball ache carrying it all about and I have been contemplating some of these for when I want to be a bit more portable. I have been using the lightning to 3.5 converter with the same headphones and they are ok. However, it’s not the best solution in the world. Aside from the fact these AirPods look completely ridiculous, how good are they? I mainly listen to FLAC files and occasionally Apple Music.![]()
Mind linking the wrap? Got some pics?They sound fantastic for their size to be fair, a good level better than stock normal headphones. I put a black and grey carbon wrap over mine and they look good now.
Keep ur expectations realistic and you will be pleased. Best sounding headphones for their size, portability and price imo.
Sure there are other great sounding in ear headphones but way more money and not as brilliant to use as these in day to day life.
Echo most of the above, I have quite a few sets of ear/headphones and use the AirPods almost daily for a few hours each day. The portability and battery life is ridiculously impressive. Sound is also pretty good - as most Apple products a little high on price, but the use and overall usability makes up for it.
@Combat squirrel I second this
Just got myself some and would maybe think about a wrap if its easy to do.
Surely you guys heard of google?
https://www.amazon.co.uk/AirPods-Ea...880&sr=8-1-fkmr0&keywords=airpods+carbon+wrap
