So, Literally out of the blue, not problems with the phone in enarly 2 years, even the battery was in good nick
Took it out of my pocket and was wierdly off, anyway, started it, screen started sideway (which is odd) then phone retarted, worked fine for about 2 minutes, then turned off, then ended up in a bootloop for about 20 minutes.
Worked again for about 10 minutes, then turned off and has now been in a bootloop for about an hour.
Apparently it can happen on this phone.
Basically its dead. Apparently on the SDA forums there is a fix, however you need to get in to your phone to enable OEM unlocking, which at the moment I cant do. So unless my phone boots, its toast.
Damn.
This was a nice phone also, was hoping it would last a few more years at least.
Damn.
Thats a epic result. Didnt think that would happen! 2 Years of free use of that phone. Wow
