Mesh WiFi a good solution for online gaming?
29 Sep 2003
Blaydon on Tyne
Hello
I’m partial to a bit of league of legends, which I play on my laptop via WiFi. I’ve got a TPLink Archer VR900 router.
If my other half is browsing the net or playing videos at the same time, I can find my ping goes up and down like a yo-yo for a while.
Would a mesh WiFi network solve this issue?
Many thanks.
M.
Hello
Many thanks.
M.
Sounds more likely a bandwidth issue. What’s your connection ?
Sounds more like you need QoS type solution. Suggest reading https://www.bufferbloat.net
I use Smart Queus on my Edge Router X-SFP and now, latency is much more controlled despite others use of the connection that I don't worry about it any more.
Even the most basic router should be able to cope with two clients gaming/streaming video.
His router supports QoS.
Basic routers, without QoS will not be OK. If the current router has QoS then it sounds like it needs to be configured....
I’m going to disagree with you there, a basic router will cope fine with multiple clients if bandwidth isn’t the issue.
If he’s got fibre and all it has is one client gaming and one browsing/gaming/streaming the issue won’t be bandwidth so QoS isn’t going to fix it. It sounds more like a hardware issue.
Browsing the net and watching video’s shouldn’t impact one another on a 76mbit connection significantly (unless your significant other is attempting to direct stream a 4K remux), a video will eat a few mbit a seccond, a brief spike where it starts to buffer, but nothing that should be noticeable.
Repeat the test with you wired (you say you use a laptop so it can’t be that hard to test with a cable), that will identify if it’s a Wi-fi related issue or connection related.
Testing with a cable will be tricky because the router is in the hall and the laptop has no Ethernet port!
Often worth checking if your upload bandwidth is saturated (e.g. torrents or malware) as that can throw latency out and cause all manner of issues. I've been caught out by that before with OneDrive using everything uploading a big file to the cloud and everything else internet related going a bit askew.
