- 13 Sep 2012
- Belfast
Hi guys, hope this is the correct section!
Okay so the situation is, I need to cut the honeycomb mesh from the front of my Corsair 650D where the 240mm intake fan sits. A very common problem with the earlier versions of the 650D was the fan sits too close to the mesh and creates a very loud wooshing/jet noise, and so I never bothered with the fan for years.
Coming into the summer though and I want to get it sorted this year to tackle temps inside my case, so I need a dremel as this seems to be the only tool I can think off that is suitable for this job. Only problem is I don’t fancy spending £50 or upwards for a good dremel just to cut out a single hole.
Has anyone had any experience buying cheaper brands of dremels around the £15-£20 mark, I would pay that but I don’t know if the cheaper brands will do the same job as say, a Dremel 3000
My options so far:
1. Suck it up, buy £50 dremel
2. Buy a cheaper brand
3. Use a different tool?
4. Or if anyone in N.Ireland has a dremel they are willing to lend.. message me please lol
Any thought or solutions would be greatly appreciated
My options so far:
