can i wash fans
5 Aug 2017
my friend gave me his old radiator with 3 120mm fractal design fans, but the radiator leaked and now they are covered in that weird watery stuff. is it safe to wash these at all? if not how can i clean them without breaking them?
Iv used cleaning/monitor wipes to clean fans/blades plenty of times in the past. As long as your not getting moisture into where the motor/bearings are you should be fine.
I have washed Corsair SP1 fans under a running tap, and then left them to dry / drain for a couple of hours before using again. I had no issues.
Most electronics are power washed at the factory, including motherboards. They have to do it to remove flux etc.
Smaller companies use dishwashers to clean PCBs after reflow soldering.
The thing you need to be careful of is that some tap water has a higher concentration of minerals and salts in it which can lead to corrosion if not dried quickly. De-ionised water takes care of most of that.
The difficult bit is drying it quickly and completely. Usually done with high airflow and heat.
https://www.youtube.com/watch?v=zRJSnPGUVa0
The only thing that would concern me is getting water into the bearings and/or washing out any lubricant in the fan.
