- 26 Sep 2017
- In the Masonic Temple
Hello,
Thanks for coming to try to help.
This is the problem in it's entirety.
The Pc worked perfectly for about a year until my old psu popped and caused the entire house to trip a fuse, (february)
I replaced the Psu with a kolink 1000w bronze and all was good until I woke up after 2 days (Pc was idle when i left it)
and in the morning the pc was off, it would not turn on unless i took out my vega 56 and turned out that the vega had died in the middle of the night and smelt of electrical burn
I RMA'd the vega and bought a second hand vega 64.
All was good for 3 days until the pc started hard resetting, sometimes 1 minute after loading a game, sometimes 3 hours after. Other times i would be using the internet with music on and it would hard reset randomly.
Things I've tried in 2 weeks:
Completely fresh install of windows
Completely resetting the bios to stock, (even running the ram at stock and not its rated mhz)
Different GPU drivers (also using driver ddu many times)
Taking out one of the sticks of ram (still happens)
Checking the voltages in various programs (everything perfect)
Running aida64 , memory cpu fsu hdd ssd gpu cache with all my ram, and with just one stick. (No crashes at all, temperatures very very good)
Running Aida64 with every thing overclocked , the cpu (4.6ghz the ram (2800mhz) and the gpu to try and make it crash (No crashes happened temps max on cpu at 75.C Gpu 70/80.C)
Changed the power strip its plugged into.
Checked and re plugged in all connections.
Please help
I don't know what else it could be, i only can think that maybe the pci slot was damaged, the motherboard itself, the cpu, or BOTH sticks of ram when the previous psu popped.
I appreciate anything you can say to help.
I5 6600k
Corsair 2666mhz ddr4
Vega 64
Kolink 1000w Bronze
samsung 750 SSD
WD Black 1 TB HDD
Please help
I5 6600k
Vega 64
Kolink 1000w Bronze
samsung 750 SSD
WD Black 1 TB HDD
