Ok so I want to upgrade my computer which I built with parts from OCUK back in 2011 and has served me well. I'm now looking to build/upgrade to something with a middle spec rather than top spec as I'll explain.
I'll keep the case and dual optical drives, card reader and psu as they're ok and replace the mobo, cpu, hard drive as the current one has some bad sectors and also fit a 250gig SSD and 8 gigs of DDR4 to start with. So far so good.
I might add that I don't presently play games ( though I'd definitely like the option later) and most of my heavier use at the moment is only a bit of Photoshop so will probably fit a graphics card of choice as and when I know what my future demands of it will actually be though even then, gaming would be more casual rather than serious.
Presently I'm looking at possibly a Ryzen 5 6-core 1600 as the cpu and maybe a mobo along the lines of this one... https://www.overclockers.co.uk/giga...ocket-am4-ddr4-atx-motherboard-mb-557-gi.html
Together with the other bits I mention, they would probably more than meet my needs though advice would be appreciated as to whether there would be better cpu/mobo combinations as the core of my new build.
In fact if you feel like it, spec me the best choice of all the bits that I need as to be honest I'm out of touch these days and any help would be definitely appreciated!
Cheers and thanks in advance.
