- 23 May 2018
People probably asked the same question hundreds of times but my situation is different (and yes, I tried googling)
I'm upgrading to an R7 2700x soon and I only have a limited set of options when it comes to RAM.
I'm also getting an x370 MSI Gaming Plus motherboard (for a lot of reasons, one of them is it's the only cheap gaming motherboard available)
G.skill AEGIS 8GB 3000 CL16
G.skill TridentZ RGB Series 16GB (2 X 8GB) DDR4 3000
G.skill Flare X Series 16GB (2 X 8GB) 3200 CL14
Crucial Ballistix Elite 8GB 3000 CL16
Crucial Ballistix Tactical 8GB 3000 CL15
Crucial Ballistix Elite 8GB 3200 CL15
(I have no problem buying any of these despite the difference in prices.. it's only $25 difference)
1- Does it matter if I get a kit of 2x 8GB or 2 separate pieces of the same module?
2- Does the G.skill Flare X perform much better than any other RAM on the 2700x or it doesn't matter?
3- Will a 3200 RAM work well without any complications on the MSI Motherboard?
Thanks.
Thanks.
