Argh just seen my 2011 MacBook Pro has been dropped from support for the next macOS. This is very sad times, as a replacement machine will be easily £1500+![]()
Is supported the same as "not available"? You may be able to install it, but it may not be technically supported.
Nope, as shown in a screenie on the previous page, it just won't install.
With Watch OS, I know that they mention new notifications but can you clear all notifications yet instead of having to clear them one by one?
You can already, just press and hold, then click "Clear All"
Not sure how many of you guys are running the beta but wow, it seems super stable at the moment and much more responsive than 11.4. First betas are usually a bit of a **** show.
Worth doing then ? Really want Watch OS 5 on my S3 as I hike all the time
Its hard to say really. My first direct banking app crashes on startup but thats the only app that isn't working so far. I haven't noticed any other issues but its a beta and different people have different issues on betas quite often. If you don't mind the odd bug/issue then its a solid beta so far but take everything I say with a pinch of salt!
This is why these days I tend to stay away from iOS betas on my iPhone - It seems every time I try the betas, they completely break all my finance apps![]()
Lol, yep, they used to kill all mine as well but this time its only the first direct one thats dead. Barclays and monzo are fine.
The feature has been in Google Photos for a while and yes, it can backfire on you horribly!
Perfect thank you! I presume this isn't the same for Mojave?
I've moved the iOS 12 posts to a new thread. It's official, it's got stars and everything![]()
