Just stay with standard design Airctic Cooling fans and avoid those F "Pro" marketing BS fans.
Those vibrate lot and without frame their airflow is only worser, because instead of actually pushing air to where it's supposed to go lots of air leaks radially away.
If motherboard has fan "open" header accepting 4-pin PWM conenctor that could be better for good scaling if you have hotter components there.
Motherboard doesn't even have to support PWM control but can use voltage control.
F8 Silent's 1200rpm max might be low in case of needing more cooling.
Though of course if default is no fan in that spot then even 1200rpm would give some airlfow and wouldn't make much noise even at full speed.
Stock fan's speeds is reasonably low, just don't have much trust for bling bling Aerocool using good design fan.
Though speed limits possible airflow noises caused by design...
https://www.aerocool.com.tw/au/chssis/pgs-c/cs101
i have always read the Nocts to be the best for quiet
Noctua is only best in hype.
NF-S12 is so quiet
per RPM because it's pressure impotent and can't really push air against any impedance.
It actually made SilentPCreview change testing method from their original, because unlike suggested by impeller anemometer testing people had temps actually increasing:
http://www.silentpcreview.com/article734-page1.html
(designed to fool impeller anemometer?)
And NF-P12 and NF-F12 which have come bundled with Noctua's expensive heatsinks (no excuses for can't afford QC) aren't that good either.
First of all both vibrate badly, which causes case (or even table if you put fan onto it) amplify noise.
And P12 has quirks developing at certain rpms some weird resonances (likely those big notches in blades) described by SPRC as airplane flying nearby.
While F12 has all around mediocre sound signature, no doubt because those motor hub supports being in same angle as/parallel to trailing edge off blades.
(which causes constant big "bumbs" for airflow pushed by blades)
For comparison from nearly dozen Scythe SlipStreams (costing one third of Noctua) I've had only two have had vibration detectable when keeping fan in hand
And they have no acoustical quirks with smooth noise scaling with airflow.
Noctua NF-R8 and Noiseblocker BlackSilent Fan XC1 have motor hubs supports partially parallel to trailing edge, so those might get noise from that at more significant speeds.
Noiseblocker BlackSilent X1/X2 again has good looking geometry.
