Hi, thanks for the help on getting me a new card, I bought this one 2nd hand ASUS Geforce GTX 1060 6GB. And its way faster than my 2x gtx 660 Ti
I have been spending the last few hrs fine tuning it but hit a brick wall and out of ideas to improve visual effects.
What is better to use a proper monitor or a TV with PC support?
My monitor I was using has the older vga adapter but the card has the newer port so I had to use an adapter 8 x3 pin with slot pin with 4 pins around it if that makes sense lol. But the new card has the modern version of the adapter the same but with out the 4 pins around the bar so mine doesnt fit, thus I cannot use the monitor till I get the new part. However I have a newish ALBA 24" HD 720p TV nothing special just the one from Argos lol. It does have PC support and also has HDMI support, I had a spare cable so hooked em up, straight away I saw a major difference, like playing a newish game allover again like it was new
. With every setting at max and ultra and max distance I still had amazing quality and FPS though I still had Vsync locked on so max FPS was a solid 60, unlocked 60 to 80 FPS, 60 looked better.
On the screen resolution I have an insane amount of levels I can have, my standard one was always 1280x1024 now my max setting is 3840x2160. I have found a balance at 1920x1080.
I am still trying to fine tune the picture, so far I figured out the win7 auto rez set up that has cleared up most of the fuzziness but still needs tweeking. At the moment the screen seems very bright and does hurt my eyes abit, I have tried adjusting the TV and the system settings, but still its just a little too bright, also the letters on desktop,word and browser internet is still a little fuzzy but better than before, is there away to improve it?
Another question, How do I change the Hertz? The max I can go to is 60Hz, I have tried other rez settings but that only goes down from 60 down to 24hz. I have been told if I remember 72/75Hz was better also stopped headaches lol. Do I need a different monitor/TV? The monitor I have is a LG FLATRON W2243S, this is an old one as only has VGA connector. I should be able to do it with the TV but not sure I can. How can I do this?
Thanks for any help
Thanks for any help
