Permabanned
- 13 Apr 2017
- scotland
You know the one, the girl sitting in the 1980s blue American saloon, but strangely it's a RHD model.
Think this is correctI had this coversation with someone. Maybe a Caprice?
I won the winnings! What do I win?![]()
EH ?Apparently it isn't unusual in ads like this to use a skeleton of a car with tracking marks and CGI the shell over the top.
A more extreme exampleI've seen a few ads shot with a more "ghetto" variation of that kind of setup.
Surely that’s a hugely expensive solution instead of using a car which is worth not very much?
It’s not a very desirable car, even in the UK - I’m sure no one said we just have a Chevy Caprice and it must be a right hooker. They presumably said we need a big American car and the caprice was the first one they came across, rare or not. I very much doubt they went to all that expense to CGI one in. I know you’re not saying they did, but it would be madness.
Not saying they all do it - but to various degrees what you see in the final ad might be nothing like when it was shot. I've seen a couple of ads shot where they used an old stripped out Ford Focus for instance with most of the panels and windows, etc. removed and a shell CGI'd on after.
Depending on the complexities of the ad it isn't necessarily that expensive - there are even highly detailed royalty free 3D models out there for a range of cars depending on what you need.
Obviously if you are just using an old banger it is probably cheaper and easier just to use the actual car - but even then some stuff might be edited like someone mentioned above even if it is just flipping the image to turn a left hand drive car into what appears to be right hand, etc.
