Hey, having major issues with my system, I bought a pre-binned 8700k at 5ghz a few months back and had it running in my old semi-custom loop with XSPC parts and along side my 1080ti in the same loop my CPU Ran warm but not to the point where it hit thermal throttle or shut down, I've yet since built a stronger watercooling loop (First time doing hardline) and I'm majorly struggling with temps, I'm getting 84 degrees at stock settings on my 8700k whilst gaming but my GPU always remains below 44-45. I cannot seem to cool my 8700k down using the new build, list of parts I use are:
CPU Block: EK-Supremacy EVO CPU Block - Black.
GPU Block: Aorus Waterforce.
Radiators: EK Tri-rad x2 with 6x ML120 Corsair RBG Fans.
Pump: EK-XTop Revo D5 PWM RBG.
Reservior: X3 150 Black.
Case NZXT H700i (Not sure if relevant, air flow seems an issue?)
Picture of the nightmare that is my PC: https://imgur.com/a/fik6ZEm
It's driving me insane prior to switching from soft tubing to hardline I was able to run it at 5ghz albeit quite hot but still I could run it, now I can't run it stock without hitting thermal throttle and soon I expect it would have shut down if I hadn't stopped gaming.
I've reversed the fans so they suck instead of blow, same problem, I've reapplied thermal paste twice, I used the one that came with the EK CPU Block. The moment I run the OC and launch OCCT and HW monitor I see it jump instantly to 86 go back down to 78s and hover around 84 before I decide that theres no way it's going to drop anytime soon. I'm pulling my hair out trying to figure this one out, I've gone from a single dual rad to 2x Tri-rads with 6x ML120s at 100% load it's still crashed on stock settings.
I've checked all the rookie mistakes like leaving any plastic films on the CPU etc the only difference to my old PC is better parts and running my fans through the Smart CAM on the case.
Flow is Res>Pump>Radiator>Radiator>GPU>CPU>Res> although from my understanding regardless of loop order by a fractional margin I can't see it making a huge impact order wise.
