Hi all,
I'm looking to upgrade my current gaming PC which is an i5 2500k running @ 4.3Ghz, with 8GB of ram. It's served me brilliantly for almost 7 years, but is struggling a bit with some newer games.
So I'm after some advice please...
I was thinking of going with the i5 8400 with 16GB of RAM, which works out about £420 on OcUK at the moment. But then I saw the i5 8600k is an extra £60, which would allow me to overclock, unlike the 8400.
My question is will the 8400 be a big performance increase over the 2500k (the fact that it's a jump of 6 generations should count for something alone, surely)? Or would I be better off paying the extra so I can overclock?
Or would you suggest something completely different?
Budget is £600 max.
I'd really appreciate your thoughts. Thanks!
Budget is £600 max.
