I need a PDF translating from Italian - any ideas?
16 Nov 2009
UK
Hi folks!
I'm writing a book about Italian swords after the Napoleonic period and I don't speak Italian (what do you mean that was poor planning?!). Most of my sources are short so I've been using Google translate but now I have a 300-page book in PDF form that I really want to read. Sadly, the text is not selectable and is a bit 'old' for the already-a-bit-dodgy Google translate camera app.
Can anyone recommend a solution to save me from hand-typing out lengthy sections?
The text is called Armamento Individuale Dell'Esercito Piemontese E Italiano.
Thanks for reading.
Plenty of pdf translator sites online. You might have to reduce the number of pages / upload them page at a time though. I had to translate a pdf from Norwegian for work. I forget the site but it was in the first few results. Only worked with printed information rather than handwritten though
It's like nobody reads posts - Google Docs does it with ease.
Thanks all, I will work through the suggestions this week. I have tried an OCR but it didn't work but I'll have another go with a different one.
Much appreciated!
Best OCR I've found is ABBYY Finereader
Expensive, but good.
Even saying that though, there will always be an error rate, & even that depends on the quality of your scan.
A good scan from a sheetfed scanner and I'd expect an error rate of ~5 words a page in older printed English text.
The error rate will go up exponentially with age and use of technical terms; The OCR software will try to intelligently correct what it sees, but this is as often as not a hindrance.
Trying to OCR then translate will probably produce iffy results unless you're prepared to read the OCR'd Italian vs. the original before trying to translate.
