- 26 Aug 2003
Hi,
I've got a few cheap power tools which see me alright at the moment, but I'm probably going to be needing an angle grinder at some point, and I'd like a cordless impact wrench. I see the various battery-sharing power tool systems and they look really convenient - but which is the most suitable for a DIY type?
The Ryobi stuff looks decent, and is reasonably priced, but is it any good? I know you can spend a lot more - is it necessary?
Tools I'd ideally like, in time:
power ratchet (this seems one of the rarer ones, Ryobi do one but can't find in UK)
impact driver
impact wrench
drill driver
hammer drill
angle grinder
Does anyone use one of these systems, and what do you think of it?
Cheers
impact driver
impact wrench
drill driver
hammer drill
angle grinder
Cheers
