I'm wanting to put something in a solid wall in my lounge to run cables from the TV to the sideboard below - what sort of thing should I be using? Is there anything designed for exactly that purpose, or should I be using some sort of heavy-duty trunking that will match up to a brush faceplate either end?
Only caveat is I need the trunking to be fairly sizeable as it needs to take the power cable, which has a chunky connector for the back of the TV. There isn't an outlet behind the TV so power cable needs to be fed from floor area.
