Looking for a new £500'ish laptop
28 Aug 2006
Hexham
I'm looking at getting a new laptop, I'd prefer 8th gen i5 8250U/i7 8550U, at least 250gb SSD (NVME if possible), decent 1080P screen, and half decent battery life, any recommendations please?
Might struggle at that price/spec
Currys have an Acer one which fits your specs for £600, alternatively Amazon do the Dell Inspiron for arond the same price
Thanks for the reply, I'm in no hurry for a new one, hopefully somewhere has a sale on soon and I can get one for a decent price, I'll check out the ones you mentioned in the meantime.
That spec new is not happening, will have to be used.
We have this which is £550 and for the money a great spec, very hard to beat for £550:
HP OMEN 15-ax009na NVIDIA GTX 950 2GB GDDR5 15.6" IPS, Intel i5-6300HQ Gaming Laptop @ £549.95 inc VAT https://www.overclockers.co.uk/hp-o...-intel-i5-6300hq-gaming-laptop-lt-03s-hp.html
15-ax009na, 15.6" LED 1920x1080, i5-6300HQ, NVIDIA GTX 950 2GB GDDR5, 1TB 7200RPM HDD, 8GB 2133MHz DDR4, Windows 10 Home (64-Bit), 1yr Warranty
Only £549.95 inc VAT.
ORDER NOW
ORDER NOW
If I was gaming at all, I'd probably be ordering one now, but for basic browsing, I'd rather have the much more efficient 8th gen, the 8250u benches very similarly to the 6300hq but with a much lower TDP, thanks for the link.
I've just ordered a Dell 5570 with the following spec from their outlet for £350 delivered, not exactly what I was looking for, but it should be fine once I add a 250gb NVME SSD drive :-
  • Certified Refurbished
  • Inspiron 15 - 5570
  • Processor: Intel® Core™ i5-8250U (Quad Core, up to 3.40 GHz, 6MB Cache, 15W)
  • Windows 10 Home (64bit)
  • 8GB (1x8GB) 2400MHz DDR4 Non-ECC
  • 1 TB SATA Hard Drive (5400 RPM)
  • Intel HD Graphics
  • Software
  • Dell Wireless 1810 Card (802.11AC Dual-Band Wi-Fi + Bluetooth 4.1)
  • LCD Back Cover - Platinum Silver (Non Touch)
  • Palmrest With Finger Print Reader
  • Primary 3-cell 42W/HR Battery
  • 15.6 Inch FHD (1920x1080) Non-Touch Anti-Glare LED-Backlit Display
  • Internal UK/Irish Keyboard
