- 28 Dec 2017
- Beds
Hey all, so I've built my first custom loop (hardline, 360mm and 120mm rads, i5-4690k and GTX 1070).
System temperatures are great - generally below 50 degrees C, maxing out at 53 under stress test. And very quiet. But I've noticed internal temperatures seem really high. Reading for PCH and that are fine, but the heatsink on the PCH is burning up. Right on the line between pain, and leaving me actually burned.
I'm using an Alphacool GPX Nexxxos block which is a hybrid block, so I know some of the heat is carried throughout that block rather than into the loop. The backplate of the GPU block is almost as hot. I'm just kind of surprised!
Right now I have two intake fans blowing from the top down, and the radiators exhausting (360mm at front, 120mm top rear). It seems like no air is reaching the centre of the case. The intake fans are fixed speed (slow), but the radiators are all on a curve based on temperature.
Any suggestions for improvements? I'm tempted to put SP fans on a PWM curve in the intake slots too...
