- 1 Dec 2015
Ah, sorry thought they had designed enough space to slip it through . Been a while since I used one
Buy a 2600K/3770K for your current system, use the spare CPU cycles from the 1440P resolution to do what you want on your second monitor.
This is at 1080P, so 1440P would be much closer
There's video, but feel free to spend £600+ for a 20% performance boost at best, over a 3770K.![]()
Thanks for the reply. I've completed the upgrade already though. Went with Ryzen 2700x.![]()
Was it worth it then?
Or just have to have shiny new shiny things?
Well I'm happy so far but to be honest I've barely used it since the upgrade.
I wanted to upgrade all 3 things and set me on for a while so hopefully I won't need to upgrade again for a while apart from the SSD.
Second hand ! Can pick up case and evga 450w for £80 but for case/PSU/card/storage for £150.. FB or the bay
GPU if your using your current one ?
I've got this in my current machine:
This is the old GPU that I still have spare:
- ZOTAC ZT-P10700B-10P GeForce GTX 1070 AMP Extreme 8GB GDDR5
- ATI Radeon 7950 HD 800MHz 3GB PCI-E HDMI Windforce 3X OC
Wipe clean your HDD when finished and pass on
My basket at Overclockers UK:
- 1 x TeamGroup 240GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive= £49.99
- 1 x Bitfenix Formula Series 550W 80 Plus Gold Power Supply= £66.95
- 1 x AeroCool Aero-300 FAW Midi-Tower - Black Window= £32.99
Tier 1/2 psu, if free shipping then could bump up to 650w - can't remember power draw of that gpu
That isn't a bad idea actually. I didn't even consider SSD for some reason, figured that might bump the price way up.
I think the minimum system power for the GPU is 500W.
