windows 10 mouse that allows you swipe left right to different desktops
Caporegime
7 Apr 2008
Lorville - Hurston
Hi.
Is there a mouse that enables 4 finger swipe actions?
On the apple mouse u are able to swipe with two fingers on the mouse to swicth to different desktops while in windows it seems you can only do it via keyboard shortcut or on a trackpad?
I have the microsoft surface mouse and it doesnt enable me to swipe between desktops
I use the Logitech MX Master and it has buttons on the side that you can assign that action to. Not quite a 'swipe' as such, but it does work very well.
can you not use the apple mouse on a windows PC ?
with an older apple blue-tooth magic mouse I found appropriate drivers
The MX Master has a gesture button. You can set it up so that you press it and then move the mouse to create a gesture. You could set that up to swipe to a new desktop.
