- 7 Apr 2009
- Western Seaboard
It didnt fall on its own, it was demolished by the same guys that put it up, you can see the forks pushing it mid way through then receding (I live 1 mins drive from it). Its in such a dangerous place in the first place, on a sloped large grass area at the front of their estate. In their race to build the biggest bonfire, physics has to come into it!
It didnt fall on its own, it was demolished by the same guys that put it up, you can see the folks pushing it mid way through then receding (I live 1 mins drive from it). Its in such a dangerous place in the first place, on a sloped large grass area at the front of their estate. In their race to build the biggest bonfire, physics has to come into it!
Hmm seems from the other angle it didnt need much help in finally going!https://i.imgur.com/6kgU9Ax.jpg
There's 2 recordings of this from 2 totally different angles and in both instances it looks as though it falls itself. The electrical cable spools they used as spacers gave way and tilted it over to one side. Of course the builders are claiming otherwise, after their structural engineering post that's hardly surprising.
