19 Jul 2018 at 19:08 #1 P.B P.B Soldato Joined 2 Apr 2015 Posts 2,651 I'm using the above spec and only getting 582 on cine bench ? Should be 700ish Any ideas as i have it stood up using external devices with 3 noctua fans in the bottom intake also had the tim swapped out so what gives ??
20 Jul 2018 at 01:22 #3 MiSJAH MiSJAH Associate Joined 30 Nov 2013 Posts 1,485 Location UK P.B said: I'm using the above spec and only getting 582 on cine bench ? Should be 700ish Any ideas as i have it stood up using external devices with 3 noctua fans in the bottom intake also had the tim swapped out so what gives ?? Click to expand... Run HWiNFO with reporting during the cinebench run and pastebin the report then link here.
20 Jul 2018 at 08:42 #4 P.B P.B Soldato OP Joined 2 Apr 2015 Posts 2,651 Ill try get that done tonight
20 Jul 2018 at 20:58 #5 P.B P.B Soldato OP Joined 2 Apr 2015 Posts 2,651 Sorted it was some thing to do with intel speedstep thanks for the help
