- 20 Oct 2002
- Oxfordshire / Bucks
At what low vehicle battery voltage does it stop charging the neo ? (how much does it leave for the vehicle) seems like it is 11.7V
expensive piece of kit though, can you accomplish the same with https://www.amazon.com/Yukuma-Power-Bank-Engineered-Certified/dp/B073PN843G or similar ?
Not sure how long it would last if its in constant use for parking mode
and could you link this to a thinkware ? (its not usb or micro usb
Could you install it in the car and forget about it like the cellink ? i wouldn't want to remove it i want to hide it away and forget
