Advice is to wait.
B450 boards are coming out soon, and you can get 2700/X with b450.
Also there's a 32inch IPS 1440p 75hz with freesync (for £220!) coming out at the end of the month
You can pair that with the rx580 8gb and that's you sorted for quite a while
expensive but hopefully drive prices competitively all aroundMight as well wait another week or so even if B450 doesn't look like it will be a massive improvement (VRM wise) over B350. At least you can see what pricing is like etc.
Your also won't have to go through the rigmorale of having to update your BIOS with a either a first gen chip or a dummy CPU form AMD.Might as well wait another week or so even if B450 doesn't look like it will be a massive improvement (VRM wise) over B350. At least you can see what pricing is like etc.
Advice is to wait.
AOC Q3279VWFD8What's the monitor??? I've got to work on it, and 32 sounds ridiculously huge for that, but I'd get used to it...
I'm happy to consider b450, but just figured I could push the cpu hard, and upgrade in 3 years to whatever amd released in 2020.
damn, B450 already listing up
https://www.gigabyte.com/Motherboard/B450-AORUS-PRO-WIFI-rev-10#kf
https://www.gigabyte.com/Motherboard/B450-AORUS-PRO-rev-10#kf
@lee32uk 8+3 set up- will have to hunt down IR units used but looking MUCH stronger. guessing lessor IR to keep price down from X470 as they have same phase count
though Gigabyte version looks to be the same lower end set up for B350 - guessing will keep pricing to £70 odd
https://www.asus.com/us/Motherboards/ROG-STRIX-B450-F-GAMING/
strix looks 6+2/7+1 . X470 was 8+2 so makes sense
depends on the price, if he's expecting a lot or higher qualit materials on the cheap... wont happen - least it has option to be overclocked![]()
Is there any difference between ram speeds and clock speeds between the motherboards? Or is that all bios/CPU based?
