- 3 Oct 2009
- Wales
I agree you should have been kept in the loop better but you have to appreciate if your solicitor updated every client every day with the current situation no progress would actually be made on anything!
He's right, not much can be done in that situation, he's not going to ring another solicitor every hour because again, nothing else would get done and he should be able to rely on them getting in contact themselves when they are ready to go. If they don't do so that's not really his fault. I'd consider checking once a day sufficient. I've had that kind of thing go on for weeks and taken verbal abuse because I should be able to make the other party answer their solicitors calls
I wish I could.
Perhaps the estate agents should be pulling their weight more there , after all they are likely getting paid 3-5x more than the solicitors...!
I wish I could.Perhaps the estate agents should be pulling their weight more there , after all they are likely getting paid 3-5x more than the solicitors...!
Their side of the indemnity is around £110 I think - Surely it's not worth them removing the oven and hob for something so small...
