Hi guys,
I need your help. I have got some scratches marks on the front and side panel. I want to get rid it but I am not sure how to do this.
Here is the pictures:
Do you know how I could remove the scratches on the front and side panel?
However, I found a video on youtube it show you how to remove it by using the spray paint on the cardboard that come with the same color, so you could use with a small paint brush to put it on where the scratches are to remove it but I am not too sure if it would work?
Here is the link:
Have anyone ever try it?
The name of the PC case I got is called Lian Li PC 61 and the color for the case is black anodized aluminum.
Any advice would be much appreciate.
Thanks in advance.
Here is the link:
Thanks in advance.
