New modem/router for Pihole?
28 Aug 2006
Hexham
I've got an old Pi 2 to have a play with, and want to use it for PiHole.
Unfortunately, I'm with Now TV, and their router (a rebadged Sky SR102 as far as I can tell) doesn't allow you to change the DNS servers, so I can't get all the internet traffic to go through the Pi.
I've got an unlocked Huwaei HG612 BT Openreach modem and a so far unused Ubiquiti Unifi AP AC Lite, would I be able to use them with the Pi, or would an all in one modem router, or just a new modem, be the better option?
Can you turn off DHCP on the SKY router? Pi-Hole can do DHCP server so you can use it to do both DNS and hand out local IP which would give you what you need. The SKY router would effectively just be a GW/Firewall then.
I've turned off DHCP and asked Pihole to do it instead, but it's still using the standard DNS on the router.
That doesn't make sense. If your Pi-Hole is doing DHCP then change it to give out the Pi-Hole's IP as DNS1 and leave DNS2 blank. Once devices re-lease their IP they will be using Pi-Hole.
There's nowhere to change the DNS settings on the router, all I can do is turn DHCP off.
Yes but DNS servers are handed out to clients via DHCP. If DHCP is off on your router and your Pi-Hole is giving out IP addresses then the Pi-Hole will dictate what IP's are given for DNS.
This can’t really happen so something isn’t right. Is your Pi’s LAN IP, upstream DNS and gateway set correctly? Do you see your networked machines in the PiHole DHCP lease table in the UI?
Something doesn't seem quite right, it's blocking a lot of adverts, but I can still see some, and the links on the Pihole site to the test sites shows adverts too.
Perhaps DNS leakage or did you set static addresses on some of the devices you experience this on when experimenting and haven’t switched back to DHCP or flushed and renewed their addresses?
Everything's always been set to DHCP, the only static address is for the Pi.
drop to a command line and type ipconfig /all on a windows pc and we will see what its doing.
If pihole is told to handle ip addressing and the computers are set to use dhcp (with auto dns) then it will work as long as the router is not trying to do it as well.
One step closer again now after I changed the DNS settings on my laptop Wi-Fi from 1.1.1.1 and 1.0.0.0.1 to obtain automatically…
Only my mobile phone to sort out now, lol!
