which deodorant or roll on do you use?
Status
Not open for further replies.
Mitchum roll on seems to be doing the trick for me in this hot weather. Ditched the sprays as they were setting off my wife’s asthma!
Are you 13?
(Come on GD you're slacking here, a page of replies and no ****take for Lynx? :confused: )
I use Sanex roll-on but it's becoming increasingly hard to find for some reason. Have they stopped making the men's version? I gave up on sprays about 20 years ago because they just make me sneeze... Hate the guys that go nuts with a spray in the gym changing rooms...
I normally find Sanex in ASDA, usually on offer too.
I use Dove Men Clean Comfort Compressed Anti-Perspirant Deodorant the basic one not the fresh or extra fresh or whatever - I find it gives decent results and has a fairly neutral clean smell so doesn't clash if you are wearing aftershave, etc. for some reason I find the basic one I stay dry while for some reason the fresh and dry variants actually make me damp even more than if I use nothing at all.
To be honest which ever is on offer in the supermarket, not fussed about buying a particular brand or specific one. Currently using one by Sure and it lasts my pretty well throughout the day.
Same here, we must both shop at the same place as Sure is what I'm using. It actually seems to work better than most I've used.
<<<<< VERY OLD JOKE ALERT >>>>>
I asked for some deodorant at Semi-chem and the girl asked " is it aerosol or the ball sort "
And I said " no, it's for under me arms "
Status
