We want case airflow from front to back as much as possible so the heated air coming off of GPU (up, down forward and back) is moved back and out of cases without moving up and into the cool intake air going to CPU cooler. We want the bottom intake to flow cool air up into GPU along with the front to back flow from lower front intake .. and I'm not sure the bottom vent and PSU cover vents are near enough to front of case to help. You will have to experiment with bottom fan on and off to see if it helps lower GPU temps. Upper front intake is flowing to CPU. Having the PCIe slot covers removed give us additional rear vent area for the front to back airflow to leave case.Right, so just bought the build, except for monitor (I'll steal the old hd TV out of my mums kitchen for testing I guess!).
Will be trying to set everything up as you've suggested, 140s blowing in, move one of the 120s to the rear, and maybe one on the bottom (where on the meshify does it actually go??). Take a few extra slots out of the bottom too for air flow.
What CPU cooler are you using?
