Use the Lexus and spend the saving on refurbishing it in the future.
700 miles a week is a lot - doing it in a crap bucket is annoying, doing it in the Lexus will be nice.
Depends what you're looking for, spec-wise.I was going to suggest an Octavia, but it seems you can get a newer and better spec'd Passat for this budget
Pretty good shout. Car throttle recently had a series on one of these. He spent a few hundred quid to buy one that had done over 400k and when they opened the engine up they were amazed how well it had worn. Supposedly still should have more hundreds of thousands of miles left in it.Depends what you're looking for, spec-wise.
I have a mkI Octy myself but in L&K trim, which includes just about every 'optional extra' they had, from alloy wheels to cruise control, full size spare, Climatronic aircon, sunroof, HIDs, leccy windows, heated leccy mirrors, heated seats, leather upholstry, yadda yadda. Gets around 45-ish doing slow commuting and easily 75+ hooning enthusiastically down the motorways. What more could you want?
But pretty much any high HP PD VAG engine would be alright, I should think - No DPF, either. I only love the Škoda because it seems the maintenance is just a little bit easier than other VAGs and equivalent models.
That was posted on Briskoda, whereupon several owners showed theirs clocked at well over 600k...Pretty good shout. Car throttle recently had a series on one of these. He spent a few hundred quid to buy one that had done over 400k and when they opened the engine up they were amazed how well it had worn. Supposedly still should have more hundreds of thousands of miles left in it.
