Opinion please - continue to try to fix or walk away
Got any further with it?
Nope. I had the ECU replaced in case it was that (used part which they recoded so a fraction of the new cost). But it wasn't that. So I'm going to get the car back to mine and then sell it as a non runner. It's a real shame because it's otherwise a very, very good car. I'm in no rush now so I may also consider having a look at it myself when it's here. It's either something catastrophic such as a timing chain issue (very common on this engine) or something minor like a faulty sensor that isn't returning any fault codes. I'd have assumed a timing chain issue if it weren't for the fact the garage have checked this several times and are adamant it's not. It has compression, fuel and spark but appears to be over fuelling for no obvious reason. I briefly discussed with a VW main dealer but they just suggested the same checks as the current garage had already done so I'd spend a lot of money there with probably a low chance of them finding anything different.
I think it would be cost effective, because the rest of the car is good and has many new parts, to get a replacement reconditioned engine, loom and all sensors. But there reaches a point where it's sometimes better to just move on and sell it to someone who could probably do that themselves a lot cheaper.
Maybe it's something to potter around with through the next few months before selling it. I'm certainly no serious mechanic but equally I am capable enough to swap sensors, etc. So I'll also consider that.
Anyway, long story short is that I'm not prepared to spend a lot more time and money on it so I think I'll move it on, with full disclosure, and consider which car to get next. It's only a car and, while the money is a bit of a kick in the nuts, it's not the end of the world.
Does it just turn over normally but not start? It has to be a sensor, surely? Especially with a replacement ECU?
If the engine itself has been confirmed as healthy then unless I'm missing something, surely there can't be anything prohibitively expensive left to check/swap?
Is it a manual or auto?
fwiw, I normally see "replace the ECU" as a garage clutching at straws. I've never had one fail on me, and when I was sure I had a faulty one I sent it off the BBA reman who sent it back saying it's absolutely fine.
My guess is the chain is stretched and only shows signs when up to temp. Throws the cam sensors off on a wobbly. I would be checking the chain tensioner and see if it is within specs. It is almost as if the garage has just thrown money at easy fixes instead of doing the major one like checking chain for stretch. All sensors can be checked with a bolt/ohm meter and a workshop manual.
I did a chain on a Nissan Primera and it was only about 15mm stretched across the whole lot but was enough to throw the cam sensors off.
Thanks again. Yes fuel pump in the tank has been checked. Yes the ECU was clutching at straws (they said so before we did it). I am also of the opinion it could be something related to chain or tensioner, but again that's been checked by two different people. Also surely that would throw up a fault on the cam sensor?
I thnk before putting it on ebay I may as well have a try at diagnosing it myself at home. I have a large garage to leave it in while I do. As I said 'm not a mechanic but I can't exactly make it any worse :)
You can check the offset values in "measure blocks" for the engine in VCDS. This should tell you if you have excessive chain stretch or not.
Definitely. Unless there is visible water ingress or something - it's a garages way of saying "we don't have a clue".
It's a shame you didn't get to the bottom of this :(
Yes, I knew it was a last throw of the dice which is why I tried a used one as I didn't have a high expectation it would fix it. I'd also love to know what it is, even just to satisfy my curiosity.
Yeah, was good they were up front about it being a long shot and that they got a second hand one recoded
My guess would be that the original high pressure pump failure has caused chaos by scattering bits of metal shavings all around the fuel system. I’m not familiar with that engine, but if it has a return system, you’ll need to drain and clean the tank, pipes, lines, filters etc. (again)
I thought a final update to this thread was in order. I did decide to cut my losses and sell the car, I had discussed options and costs at length with the garage and also discussed more briefly with a VW dealer. Initially I was frustrated enough to book it into WBAC. But a couple of hours before it was due to be taken there I just couldn't let myself sell it at such a low price. So I put it on ebay instead which was, err, was quite "entertaining" to say the least (dozens of messages within minutes asking for a "best" price).
In the end I sold it for more than twice what WBAC had initially offered (and they no doubt would have low balled even further if I had actually taken it to them). So in the end I did take a financial hit and it is sad to see the family car go. But on the other hand I got an OK price for it, considering it was a non runner at that point, and I can move on with my life and look at what to get next.
Thanks for any advice and opinions given during the thread.
it will be interesting to know if he gets to the bottom of the issue!
That is the most annoying thing. I'll never know what the problem was. Ultimately it was cheap enough for the trader to spend time and money swapping everything until they find the fix. So they still got a bargain.
Just waiting on the I bought a car and it doesn't run properly when up to temp thread now :p
lol
I have a situation with my Golf which has got to the point where I need to make a decision on whether to continue fixing it or just walk away. I'd be interested in opinions before I make a rash decision.
Car
2009 VW Golf GTI
Approx 90k miles.
Value (if running): I'd guess about £5k to £6k. This is just a guess and I may be wrong.
I am the second owner. The car was bought as approved used from VW approximately 6 years ago.
The car is in generally very good condition apart from a scuffed front wheel.
Leather interior (only mentioned in case it alters resale value as that's fairly unusual)
Other expenses due...
1) It is due for an annual service and MOT imminently.
2) To pass the MOT I need to replace the front discs and pads, and also the rear pads.
Background
About two months ago the car would not start. There are no fault codes showing. The RAC could not diagnose it so I had it towed to my regular indy garage.
The car appears to be massively over fueling. They found a small amount of swarf in the fuel system and suspected this may have damaged the injectors. So far we have replaced all four injectors, the high pressure fuel pump (which could have been the cause of the swarf), fuel filter and fuel, with the fuel system being flushed out. After doing this the car started and ran OK for a short time while it got up to temperature. The next day they road tested it and it spluttered, then failed to start again. Before replacing them we did have a conversation that they could not be sure they would fix the issue but appeared to be the most likely cause. So I am not at all complaining about this work. It was my decision along with their guidance. I took a chance and it didn't pay off.
No fault codes have ever shown (one minor fault code does show with the radio antennae, indicating the fault code system itself is working)
After considerable testing the garage have not been able to diagnose the issue. The garage is run by ex-VW mechanics and an ex-VW 'master-tec' and I have used them for many years. I trust their work and have a good relationship with them. They have been doing most of the diagnostic work for free. Several mechanics have looked at the car and started right back at basics checking compression, fuel pump, spark, etc, etc. They have also taken the car to another garage they work with for a second opinion but they were unable to diagnose the issue.
The car has been with them for almost two months with regular updates about what they are checking and testing. So the garage has put considerable effort into it.
Options
1) Start replacing random parts... The garage have advised the next step would be to have the ECU tested. However they have also said that in the past they have sent ECU's away for testing and they have come back as OK, despite later being found to be faulty when they have finally replaced it. So while they are happy to offer this option they advised the test results are not always accurate and it may be better to replace the ECU with a known working one. There is no indication the ECU is at fault and after replacing it we may be looking at trying something else. But it is their next best opinion after the injectors and fuel pump.
2) Take it to VW to see whether they can diagnose it. The current garage advise they do have access to the same diagnostics equipment which the VW garage would have. Once at VW the costs will start mounting considerably.
3) Quit my losses, sell the car as not running and just move onto something else with the little money I recover from it.
Money is quite tight at the moment as we are pilling everything into refurbishing a house. So none of the options are ideal. Therefore the worst case scenario would be to keep chasing a fix, incurring additional cost, and eroding any money I have for another car.
Opinions? Thanks.
For me the only option is Option 3 but trade in at a garage if you can. They very rarely check trade ins beyond a quick pop round the block and focus on exterior and interior condition, so unless it’s a total non-runner then take this route or WeBuyAnyCar type places and keep your Karma.
If you have a good credit history look into personal leasing, there are some amazing deals out there. I’ve used Select Contracts and Rivervale before and are both good.
Thanks. Appreciate the recommendation. But it's already with them! :D That's the guys I always use. I agree, I only take my cars there. If it were somewhere else then I would question their diagnostics but I know they are doing everything they can.
I can third that recommendation, but seriously with nothing to go on in terms of fault codes you will in all seriousness just be wasting money. If you insist on swapping out parts try salvage yards for write offs, paying even OEM VW parts is an expensive business. If it helps we just sold my partners VW Golf 2.0TDI DSG Match and just took the hit on it as it kept costing money.
