The 2nd PCIEX16 slot operates at up to x4 mode when ATI CrossFireX™ is enabled.
If you run a single card in the second slot is it running at x16 or is it hard wired to x4 regardless of CrossFire?
Thanks
It's an old Gigabyte 1156 board that my friend says has a dodgy 1st slot , I didn't realise it varied between boards so i'll pass on the info that he can look at the slot.
Thanks both.
Bear in mind that there's not much performance loss for 8x lanes. Not sure how much there would be for going down to 4x lanes, probably only a few %. Depends on the card and resolution too.It's an old Gigabyte 1156 board that my friend says has a dodgy 1st slot , I didn't realise it varied between boards so i'll pass on the info that he can look at the slot.
Thanks both.
