Hi there
So some more work on the car today, started by removing the door trims and yep quite a bit of dirt behind them:
All cleaned and waxed, then re-fitted:
Then decided to prepare the cars paint for correction and polishing which will come in a few weeks, as such washed it and then gave the car some clay bar action, oh my was it covered in crap and remember I have washed the car a couple of times now including treatment with fall out remover, goes to show how effective a clay bar is:
Car was then washed again and I gave it a very quick going over with Aqua Wax simply as its so easy to apply, spray on wet car, wipe down and buff, literally five minutes and gives protection for a few weeks, car is starting to look really good now:
Of course then it rained, but now the car actually beads even with a basic wax coating:
Next step on the bodywork will be putting the Chipex kit to work to see how well it can deal with the deep scratches and paint chips, I will also remove the sills at somepoint soon as well to clean behind those.
