Why is it that most current Mains>Low voltage power supplies (That power almost everything nowadays) seem to have been designed by Jerks??
What I mean is this. They almost all nowadays protrude above the "Earth" pin location by a sufficient distance that they cannot be used in conjunction with the "Cube" style multi adapter because the protruding part will either foul against the wall or against the cable of the plug immediately above it (If you see what I mean)
Its like engineers design products nowadays with no real consideration on how they are going to be used. :/
And this isn't just me. Practically everybody I know in the "Real World" finds this an utter PITA!
<Just a vent really, nothing is going to change...
so prob not what you want to over load in the first place.
