Turing Up Close (yes i'm at siggraph)
7 Feb 2015
South West
Got some piccies and info here.
The tensor cores will be open for use by anyone for AI work or RTX. NVlink also allows faster and more native memory unification between cards but multi GPU still needs to be explicitly coded for, no auto free meal as it seemed.
Quadro RTX 6000 uses the TU104 die with 3072 cuda cores and has 4 DP and one usb-c virtual link port.
Thank you for the pics, that is great, but are you sure about that core count. As NVidia's own page says different.
https://www.nvidia.com/en-gb/design-visualization/quadro-desktop-gpus/ Click quick specs.
You do realise that by wearing those socks you've granted Nvidia *ahem* 'sole' use of your foot and all right henceforth. Jensen will be skinning your toes for his next jacket ;)
Do the socks have Heel-Sync?
I accidentally "overclocked" them this morning when I stood on my watch.
Nice to see some real info about the new cards.
I notice the power connections are on the end of the card too.
yes, it does seem that the Quadro and consumer parts are using different PCB's, shown by the short edge power connectors and the sync ports on the long edge. Both of those are missing on the leaked 2080 PCB.
was going to try blagging a radeon pro lanyard. All I have is my notepad and radeon pro pen.
but yeah, AMD give you two full socks while intel gives you one sock with hyperstitching.
Also, when you want to wear team colours but your shirt is having an identity crisis.
Those Nvidia socks will only work with nvidia footware :(
When will nvidia embrace open source sock technology?
