- 29 Dec 2009
With all that power on front wheels, what tyres do you use? Have you tried some semi slicks on track, something like Yoko AO48s?
Thanks
Yeah just sounds ridiculous doesn't it, the more I think about it the more I think the best choice is to scrub speed before the turn and just go in slower rather than actually try it flat out.
130mph led to my slide where I bottled it and tried to go down without no acceleration.
I know if I'm still on the accelerator to keep the weight backwards then it'll be at 150mph before it straightens up a bit .
Have you took the SVR to Donington? What sort of speeds are you seeing by the time you get to the turn in (roughly where I've put 130mph below) ? Or I'd imagine the M3 can get up to 130mph if you're pinning it from before Hollywood ?
I guess I'm just too used to having to nail the throttle in 200bhp N/A and going "too fast" wasn't a worry back then haha
Hope that makes sense, whiskey brain![]()
Impressive stuff. I also had a turbo fwd Civic, many years ago. EG6 running about 240bhp and it was a handful. 0-60 5.7 I think and 1/4 mile 13.9. I was on standard road tyres and it had plenty of wheelspin. I do think Santa Pod is kind of greasy, getting a good launch is difficult.
Where in Warks are you? I'm in the hole that is Nuneaton.
Yeah I'm going a bit all-in with this one because of all the cars I've driven, I know I can live with an FN2 for a good amount of time.
Which is probably a bit of a fallacy seeing as it's at the point where it's a Friday/weekend car now considering the fuel usage
Nice, I'd love to have a somewhat sleeper-ish clean EG/EF/DC at some point, would be a riot, I'd probably go K-swapped with ITBs for a new experience.
I'm just outside Bulkington - Ansty/Shilton area on the way to the M6 J2 if you know it.
Might have to look into York Raceway to see if they have a better surface for a day next year.
The other weekend at Pod, a few people said they weren't prepping the track at all that day - I think they were in April though? Unless somebody dropped fluid and they were doing it as part of the clean-up process.
Half cage arrived to work today so turned up 30mins before I start thinking I'd be able to get it in and fitted via the boot...
Nope! Needs the front seats and centre console out to get it in via front doors, and maybe even a drill.
