Linux remote desktop software?
27 Sep 2009
At the moment I use Multiplicity and Windows 10. This is great because I can use the KVM feature to "remote desktop" into a remote PC.
But I cannot find a good equivalent for Ubuntu/CentOS :(
OP
27 Sep 2009
Teamview is way too expensive now, my budget is £30 per year. Also I need to be able to see the screen connected to the PC from my remote PC, kinda like remote support.
7 Aug 2017
location location
Ubuntu comes with vino-server (type "Desktop Sharing" into the dash) to provide remote desktop functionality. It should work with whatever VNC client you choose; if you're on a Ubuntu host, Remmina can do VNC, otherwise there's loads of VNC clients on Windows.
SMN
SMN
2 Nov 2008
The ether
Start a session with 'vncserver' on the CLI, ensure the ports are open (i.e. a range of 5900 to 5905) then use something like RealVNC client to connect in.
19 Oct 2002
Bath
This. You can use the standard Windows Remote Desktop client to connect to a Linux machine or a Windows machine, and it works flawlessly. I've used it to remote into a Raspberry Pi if I wanted to do something that would have been a pain using SSH.
Unless you are using Debian/Ubuntu then it won't work due to a bug
