Hi all!
I'm getting my living room in shape and have a question regarding extension cables & plugs.
I have just the one socket on the wall where my TV is on, so I have bought a 1m 6 socket surge protected extension cable for all the gadgets, such as; router, Virgin Box, Playstation, TV etc.
I have punched a hole in the wall where my TV is mounted, and punched another hole down where the TV stand sits (so the cables are hidden in the wall).
I have two problems I need to solve:
1. TV Plug - So I need to feed the power cable for the TV through the hole and out the hole down the bottom. I have put a double socket back box into both the holes, and plan to put a cover on it that just lets the cables pull through a hole - Like this. I currently only have a small hole in the back box that feeds through cabling, such as HDMI and ethernet, so a plug won't go through. I've thought of a couple of solutions to get the plug down to the bottom hole:
- Cut the plug off and reconnect the plug once I have fed the cable down (I'm worried this will effect a warranty call if I should need it in the future?)
- Cut a giant hole in the back of the back box to feed the plug through
Any thoughts on this?
2. Extension - Once I have the plug down the bottom, it isn't long enough to reach the extension cable. So I was thinking of getting a single socket and single plug extension cable to plug the TV into, and then plug the other end into the 6 socket extension cable. I've heard you shouldn't plug other extension cables into another extension cable, so I wondered if this was OK to do? I thought considering it's just the one socket/plug, that it should be OK?
I've drawn this masterpiece to better explain what I want to do
Any advise with this would be greatly appreciated
Thanks,
Marky
Thanks,
Marky
