Lol my phone's arrived. No text in advance though.
How do you know it's at the store?
I traded mine in at the CPW store and waiting for a text.
There are some tests but they didn't seem to be tested in the same environment and at different status's, so there couldn't be any stats taken from them, I'm sure some will come soon which can be set so the phones are near to the same setup as possibleis there any reviews or tests where they show the 8gb ram version showing an improvement in performance compared to the 6gb ram version ?
Thanks..There are some tests but they didn't seem to be tested in the same environment and at different status's, so there couldn't be any stats taken from them, I'm sure so will come soon which can be set so the phones are near to the same setup as possible
OK I thought the trade in needed to be initiated within 24hrs of the pre order. Best check the fine print.
I've ordered the 512gb and I got a dispatched email yesterday. It's being delivered to my local store.
Thst better be the case now. I ordered it on the 11th
CPW saying it needs to be done in the same transaction. No where was I informed of that though.
The steps guideline simply days you have to request a trade in after ordering a phone. No reason to suspect the process is time limited in order to screw customers. Logically makes sense to do trade-in after receiving phone.
Customer services have accepted this so going in store to do trade in now.
DPD just delivered mine. I traded my S8+ in against it and there was no way of linking the purchase and trade-in online.
Read all the T&C's and followed the instructions to the letter. Seems to be they'll link it up against your address.
Will find out in the next few days. Fingers crossed its straightforward.
Same, There was no way of linking it.
Ive just received my note 9 and im posting my note 8 off a little later to them. Ive just attached a note with my not 9 pre-order number. It looks like the CPW note 9's are single sim, Well mine is anyway which is a bit of a shame.
