...if you put them side by side, would you not eventually slow down enough that you could land safely?
This is what I’d do.
On another note, I wonder what would happen if you shot yourself with a portal gun by accident?
Surely you'd still die due to speed you'd pick up, I mean we're you gonna shoot the over portal to come out?
Not like you have many options mid air
If you shot both in the ground next to each other be stuck in a loop at a high speed.
Shot both next to each other you'll fly up less than you fell, repeat over and over each time you'll go up less due to mavity and wind resistance eventually you'll be going slow enough you just pop out and are safe
Thread winner.Have the opening of the portal above your mum.
A portal gun needs a surface to attach to so pointing it sideways wouldn’t work
Savage.Have the opening of the portal above your mum.
Once we leave the EU and no longer have to follow their mandatory laws of physics, the op’s question becomes moot.
First portal onto floor (anywhere but ideally strategic).
Second portal onto floor immediately before landing, shooting you out of the first portal.
Repeat steps 1 and 2 until you shoot up towards a plane / mountain. Replace either portal 1 or 2 onto plane / mountain when at zero velocity or close thereto, shoot out of the ground at reduced speed.
Repeat steps until at safe speed to land onto ground.
Or, just portal up to the moon for the lols.
