Wouldn't bother cutting the holes in the ceiling to fit that junk, it will sounds terrible.
Hopefully @lucid will be around at some-point, i purchased my bathroom ceiling speaker from him and it sounds superb.
Would an up market bluetooth speaker be an alternative? That's what I do, though mine is actually a pretty cheap one for what I need.
Like a sorta battery powered movable one?
How much was that? It’s a real luxury so I didn’t want to spend a ton, if a cheap speaker sounds crap I’ll leave it
The Sonos Play One is humidity and moisture resistant and ideal for the bathroom. Whats more the Play One has Alexa built in. The only issues you're going to have is getting power to it. Admittedly it's not ceiling mounted, but I bet it would sound better than a ceiling mounted unit anyway, especially a cheap one!
