so I have always used windows for work, leisure etc.
happy to build, upgrade and all that but im at a stage where I want to scratch the whole mac/MacBook itch.
The downside is that I have never used the apple systems other than my ipad and iphone.
with the newer macbooks I know its not upgradeable once purchased so Im looking at futureproofing as best as possible.
I have spec'd a MacBook pro six core CPU with 32gb Ram, 512 SSD and 4gb GFX card. This may be a bit of overkill as my usage isn't one that relies heavily on performance but as time has shown we use to happily use a pc with 2gb then 4gb to where we are now were 8/16gb seems to be the figure people look for at minimum.
My concerns are more so to do with the problems MacBook have been highlighted with the keyboard issues etc. How much of an issue is this? and is it a frequent problem?
Cost wise, its not cheap entering the wonderful world of Mac so have started looking in to different specs with my eyes open. I know going via windows will be cheaper (slightly cheaper in some cases) but I have a desktop that I can still mess about with if needs be. financially im quite stable, not many outgoings, most of the stuff I own is paid outright so the cost isn't as daunting as if I was pinching pennies to buy it.
Anything else I should take in to consideration?
sorry for the long post but thanks in advance for any advice
