Can I replace my Cassette without replacing chain etc.
7 Oct 2003
Nottingham
I’m off to Mallorca with my Ultegra R8000 equipped Ribble Gran Fondo at the weekend but beginning to wish I had a 11/32 instead of the 11/30 cassette with compact 50/34 I have just to give me that bail out option for some of the tougher climbs. Thing is I have a short cage mech which I don’t want to change or even the chain. Simply put can I swap out my 11/30 for 11/32 with only adjustments?
28 Oct 2006
Sufferlandria
Technically, I think that the spec says the short cage doesnt work with a 32 tooth cassette sprocket but in reality I've seen people running that setup with no problems.
I dont think you'd need it really. The climbs in Mallorca are not too steep.
edit: missed the actual question asked in OP! Doh!
Yes, you can change the cassette without swapping the chain. If the chain is worn it'll also wear the cassette a lot faster. So it's not advisable if the chain is old but would be fine if the chain is fairly new.
OP
7 Oct 2003
Nottingham
Cheers touch, the chain as only done around 600 miles, only had this bike a few months so in good condition. I know it’s not really steap in Mallorca but they’re very long! I’m tempted to try for the sake of £50 but others have said like you I’ll be fine with 11/30
24 Mar 2006
You should be fine changing the cassette. But as @touch has mentioned, the climbs are not really steep. I don't think you will need it. 30 at the back with 34 at the front should be ample.
9 Nov 2005
Southampton
Should be fine on a typical 600 miles old chain.
I've no experience of pushing the limits of what a short cage rear mech can do, an 11-32 might be fine, don't forget there's also 11-34 cassettes now... But that might be really pushing a short mech too far and I've yet to see the sprocket jumps on it (I presume it will be 26-30-34, as the 11-34 finishes 25-28-32 iirc).
1 Mar 2010
maybe you now know the answer ?
but is the existing chain long enough .. if they were mean on the links they used setting up your bike originally ?
I would get one speculatively from wiggle too, and return if not needed
28 Oct 2006
Sufferlandria
That wouldn't be a problem unless he's massively cross-chaining by riding in the 50 chainring and 32 sprocket.
25 Sep 2006
Such a negligible difference between a 30 to 32t.
If you were going from a 25t to a 30t/32t I'd say it'd warrant the faff.
Nothing severe/steep enough out there to need any 'bail out' gear on the grades are all single digit so just pace it differently.
